Jul 17th, 2024, 10:32pm
veriloga code of a switch (Read 8106 times)
jovial
Jun 25th, 2013, 6:20am
Hello everyone!!
I am modeling a simple voltage controlled switch which shld be a short ckt when control voltage is high, and open otherwise.
But the switch doesn't seem to work..
Can someone tell the mistake in my code given below...
`include "disciplines.vams"
module dig_ctrl_switch_va (p, n, ps, ns);
   parameter real thresh=0.9;                  // threshold (V)
   parameter real ron=10 from (1:inf);            // on resistance (Ohms)
   parameter real roff=100M from [1:inf);       // off  resistance (Ohms)
   input ps, ns;
   electrical p, n, ps, ns;
   analog begin
     @(cross( V(ps,ns) - thresh, 0 ))
         $discontinuity(0);
     if (V(ps,ns) > thresh)
         I(p,n) <+ V(p,n)/ron;
     else
         I(p,n) <+ V(p,n)/roff;
Frank Wiedmann
Munich, Germany
Re: veriloga code of a switch
Reply #1 - Jun 25th, 2013, 8:40am
You don't tell us what exactly is not working (error messages, simulation results, ...). However, it is obvious that your coding style can be improved. Take a look at chapter 3 "AMS Behavioral Modeling" of the Mixed-Signal Methodology Guide, which is available in four pdf files from http://www.eetimes.com/electronics-blogs/eda-designline-blog/4397605/Book-excerp.... I would recommend you to use a transition function as shown on page 59 (the example is in Verilog-AMS, but a similar approach can be used in Verilog-A). By the way, Spectre has a similar component already built in, see http://www.cadence.com/community/forums/T/26543.aspx.
boe
Reply #2 - Jun 25th, 2013, 8:41am
Jovial,
see LRM:
"You must declare the port direction for every port in the list of ports section of the module
declaration. To declare the direction of a port, use one of the following three syntaxes. ..."
Otherwise the code seems OK.
- B O E
boe
Reply #3 - Jun 25th, 2013, 8:43am
Frank,
I fully agree. However, the V-AMS section of this site does offer a very similar example. So it should work.
- B O E
Frank Wiedmann
Munich, Germany
Reply #4 - Jun 25th, 2013, 8:49am
It will probably work in simple circuits, but it might cause convergence problems in more complex ones.
boe
Reply #5 - Jun 25th, 2013, 8:53am
Frank,
I also prefer the transition method...
- B O E
