thomasross20
So when a typical bandgap starts up we're in open loop, forcing some node such that current starts to flow in the circuit. Before the bandgap voltage is reached, the start-up circuit turns off (otherwise it'd always be on). How then does the circuit know to keep increasing in voltage rather than return back to the 'zero' state? There needs to be enough loop gain AT THIS POINT, but just how much?
Say VREF got up to 0.8V, so there are 0.4V to go to reach 1.2V. Is this related to the geometric series (e.g. you only need a small gain>1 or so which is consequently multiplied up and up until 1.2V is reached)? Who actually figures out the numbers when designing these circuits as opposed to relying on transient start-up sims. Is there a rule of thumb figure for desired gain (I guess this related to the difference between 1.2V and whatever voltage VREF is at when the start-up turns off)? I guess 'r' of the geometric series would be the loop gain and 'a' would be the initial voltage when the start-up circuit turns off.
Thanks!
