Sep 4th, 2024, 3:11pm
OP-amp HD5 is greater than HD3 (Read 1669 times)
neoflash
Mixed-Signal
Designer
Jun 28th, 2013, 4:54pm
I have a high speed class A/B amplifier whose HD5 is greater than HD3 in higher frequency. While in lower frequency, HD5 is about 6dB-10dB lower.
I never seen HD5 > HD3 before, anything can cause this?
Kevin Aylward
Re: OP-amp HD5 is greater than HD3
Reply #1 - Jul 7th, 2013, 1:52am
In general, this type of behaviour is intrinsically inherent in a power series expansion of a non-linear transfer function. Considering terms like a3.v^3 + a5.v^5, if the circuit does not clip on such large signals, the 5th order term will always, at some point, produce a larger level than its lower orders as the signal in increased.
Kevin Aylward
