Hi folks!
Frequently designers are using decoupling/bypass capacitor in analog design. For instance, in current mirrors: from common gates point to GND/VDD or from biasing point of cascode to GND/VDD. It good practice for filling empty places of layout, for example in standard cells =). But, really, how much value of capacitor is needed? Is hard to predict, where is standard cell will be used. Say, what a generator will be closed to this cell?...
Moreover, the decoupling/bypass capacitors in parallel with transistors with some gm and have ESR and ESL parasitics...
Please, explain for me simple (or not) method for calculate required values of decoupling/bypass capacitor (say for protection from generator on few MHz) or some common method for STD cells... Otherwise, using the capacitor for this case is only eating of chip area...
![Angry Angry](https://designers-guide.org/forum/Templates/Forum/default/angry.gif)
First of all, please explain me nature of bypass/decoupling protection...
Thanks!
