Aug 15th, 2024, 4:47pm
Ring oscillator phase noise problem (Read 4021 times)
aaron_do
Jul 09th, 2013, 10:25pm
I designed a ring oscillator using 40nm CMOS technology, and I noticed that the noise plateaus around 100kHz and below. Above 100 kHz it has a 1/f2 shape. Has anybody encountered this phenomenon before?
I tried taking the basic transconductor cell and simulating it using noise analysis, and the flicker noise is still there.
thanks,
Aaron
Re: Ring oscillator phase noise problem
Reply #1 - Jul 10th, 2013, 2:06am
See http://www.designers-guide.org/Theory/cyclo-preso.pdf. Particularly the discussion of linewidth on page 30.
« Last Edit: Jul 10th, 2013, 4:44am by Ken Kundert »
aaron_do
Reply #2 - Jul 10th, 2013, 2:14am
Thanks for the reply....
I just found the problem. I had "lorentzian" selected in the pnoise options. It resulted in the phase noise flattening out at lower frequencies.
Aaron
aaron_do
Reply #3 - Jul 10th, 2013, 2:45am
Hi Ken,
seems that you might mean I should look at page 31 right? It says that the phase noise as expressed as a voltage spectrum should flatten out near the carrier. Does this have anything to do with selecting "lorentzian" in the pnoise options?
I wonder what is the relevance of this? Since for my application I am concerned with jitter, I guess I should be more concerned with phase noise as expressed as phase rather than voltage.
thanks,
Aaron
Reply #4 - Jul 10th, 2013, 4:52am
Small signal methods do not naturally predict the flattening at low frequencies. However, the latest versions of the various RF simulators fit a Lorentzian shape to the data, which then shows the flattening.
I recommend that you read the entire paper and try to understand cyclostationary noise as a whole. It is hard for me to give you guidance on this subject with just a few sentences. You really need to understand the subtleties to assure you are doing everything correctly.
aaron_do
Reply #5 - Jul 10th, 2013, 9:15pm
Ok. Thanks for the help.
Aaron
