Jul 26th, 2024, 7:30am
MIM CAP shielding problem (Read 2435 times)
abcyin_DG
Jul 16th, 2013, 11:29pm
Hi, all,
In some processes, I see some mim-caps are shielded with lower metal layer beneath the capacitor plates, and the design manual will suggest to connect the shielding to ground.
I am wondering that whether the shielding is necessary for RFIC purpose? and what's the difference between connecting to GND and VDD? which one is better?
Best wishes,
abcyin
raja.cedt
Re: MIM CAP shielding problem
Reply #1 - Jul 18th, 2013, 12:39am
As far as shielding concern, there is no difference between vdd and vss. But keep in mind that shielding will increase capacitive load and keeping ac gnd under the capacitor will only shield against substrate noise. Even there are other techniques like keeping an nwell, or keeping poly shield which will add less capacitance compared to metal layers.
Have fun,
Raj.
