Jul 16th, 2024, 11:14pm
class E PA (Read 3570 times)
grosser
class E PA
Jul 19th, 2013, 11:05am
hello,
Can you advice any circuit solution which could help achieve good harmonics supression in such circuit ?
I mean harmonics in RFC current.
bests
grosser
aaron_do
Re: class E PA
Reply #1 - Jul 21st, 2013, 8:15pm
I thought RF chokes normally give a constant current?
Aaron
grosser
Re: class E PA
Reply #2 - Jul 22nd, 2013, 12:54am
and that's it ?
is that all of your help ?
it gives a constant current if it's not switched like in this case.
grosser
aaron_do
Re: class E PA
Reply #3 - Jul 22nd, 2013, 1:58am
OK fair enough, it wasn't much help  :P
But if it is really acting like an RFC, I think it is still supposed to provide constant current right? What I'm getting at is are you really using an RFC? Because I've seen several works using bonding wires trying to emulate RFCs. Or maybe you're saying that it is an RFC, but its not ideal, so there's still some harmonic current flowing through? Correct me if I'm wrong here.
In terms of minimizing harmonics, the methods that come to mind involve Push-Pull structures, changing the terminating impedance, using a more linear class of operation, some kind of pre-distortion, or negative feedback. For class E PAs, I'm not sure which of those apply, because you need specific current and voltage waveforms to get good efficiency. Maybe you could define the scope of your problem more completely...
Aaron
grosser
Re: class E PA
Reply #4 - Jul 22nd, 2013, 2:38am
aaron_do wrote on Jul 22nd, 2013, 1:58am:
Aaron
Yes. You're completely right. I forgot to remove RFC from jpeg.
The inductance i use is specified to be a short range antenna, to power up sensors when are in its range.
It's driven by 10MHz sqare wave and the antenna propagates awful harmonics upto 1G
grosser
aaron_do
Re: class E PA
Reply #5 - Jul 22nd, 2013, 4:51am
it looks like whatever you do you are gonna sacrifice efficiency. Is the design supposed to be fully integrated or are you simply trying to patch up your current design? Also, how much power are we talking?
If its only 10 MHz, you can use SMD capacitors/inductors to design an LC filter. Or maybe you can just not drive it so hard (or not with a square wave).
Anyway, I think you will need to give more information if you want a better answer.
cheers,
Aaron
