Sep 20th, 2026, 2:50pm
Probes handling in HSPICE (Read 3852 times)
bobp2
Aug 03rd, 2013, 11:27am
Dear all
I need some  help to interpret correctly HSPICE's results concerning probes.
my spice file  is   test.net
hdl  'probe.va'
v1 1 0 10
x1 1 0 probe r=1
.op
.end
Case 1 : I use the following veriloga file
module probe(p, n);
inout p, n;
electrical p, n;
parameter real r=1 exclude 0;
analog
    $display("##%g",I(p));
For this  current probe HSPICE outputs:
##-2e+14
Case 2: Change  the unnamed branch as follows
$display("##%g",I(p,n));
Output is:
##-0
Case 3: Change  the branch current probe to port current probe
$display("##%g",I(<p>));
Output is:
##-0
Case 4: Add a new branch  and probe   its flow
branch (p,n) bprobe;
 $display("##%g",I(bprobe));
Output is :
##-2e+14
Case 5: contribute to the unnamed branch
module probe(p, n);
inout p, n;
electrical p, n;
analog begin
    I(p,n)  <+ V(p,n)/r;
Output is :
##-5
Renew all these 5 examples with a current source connected  to the veriloga instance to obtain case 6 to 10
HSPICE outputs -5  for all the  cases
These results are confusing.
For Case 1 and Case2, it seems that a minimal conductance is used to avoid the short circuit of the voltage source  but why Case2 and Case2 are giving differents results. Case3 and Case4  seems ok but how interpret Case5 ?.
Similar questions for the current source cases.
Need help to interpret these results.
Best regards
Re: Probes handling in HSPICE
Reply #1 - Nov 5th, 2013, 8:07am
You said you had
v1 1 0 10
x1 1 0 probe r=1
so I don't see where the 5 comes from -- did you have 5V instead of 10V?  r=2 instead of r=1?
Reply #2 - Nov 5th, 2013, 8:12am
I would have said that all of these forms:
 I(p)
 I(p,n)
 I(bprobe)
would short the "p" terminal to ground, and I would have expected the same answer for all of them.  I(p) implicitly connects to ground; the other two connect to ground because of how the instance is wired in the netlist.
I(<p>) is slightly different, because it asks for the port current, but there is no current in the module (no current in any named or unnamed branch connecting to p).
