Sep 2nd, 2024, 11:19pm
Does the length of mos can exceed the upper limit in PDK? (Read 4525 times)
xianweng
Aug 08th, 2013, 8:40am
Hi,all
Does the length of mos can exceed the upper limit in PDK? For example,if the max length of mos is 10u in PDK.Does the length of mos can exceed it just as a capacitance for filter purpose ?
Thanks any help in advance
boe
Re: Does the length of mos can exceed the upper limit in PDK?
Reply #1 - Aug 9th, 2013, 1:35am
Hi xianweng,
what does the DRM say?
- B O E
xianweng
Reply #2 - Aug 9th, 2013, 4:26am
who is DRM
Kevin Aylward
Reply #3 - Aug 9th, 2013, 7:40am
Usually the limit is set to those allowed by the Design Rules of the process. A waiver may be available at your own risk.  For a capacitor, just use more devices in parallel. For use as a long mosfet, use several in series with their gates tied together.
Kevin Aylward
boe
Reply #4 - Aug 9th, 2013, 12:12pm
@xianweng: DRM = Design Rule Manual.
@Kevin Aylward: Sound advice.
- B O E
xianweng
Reply #5 - Aug 10th, 2013, 3:32am
Kevin Aylward wrote on Aug 9th, 2013, 7:40am:
Kevin_Aylward ,thank you for your reply.
We want to change technology of a chip that layout were already done .In that version ,some length of decouple capacitance (mos as capacitance)exceed the new pdk's limit.
In design rule,it just say the min length of mos,but do not say the max,so I think i will be ok if L exceed the pdk limit just as capacitance
xianweng
Reply #6 - Aug 10th, 2013, 3:33am
boe wrote on Aug 9th, 2013, 12:12pm:
- B O E
B O E,thank you for your reply
avlsi
singapore
Reply #7 - Aug 15th, 2013, 8:04am
If you want higher Length permitted than PDK. Just stack the transistors!!!
Winners never Quit,Quitters never Win
