Sep 3rd, 2024, 3:23am
Vdsat vs VOD (Read 4705 times)
ortali
Vdsat vs VOD
Aug 12th, 2013, 12:50am
Hi Guys, I simulate a transistor in hspice, which I want to put in saturation. I recieve vdsat = 110mV, vod = 146mV, vds=142mV. The simulator states that the transistor is in linear region.
I thought that saturation happens when vds> vdsat, however, it seems that vds also must be bigger than vod. Is this correct? It is 0.065u technology, and the L=0.5u.
Thanks a lot,
Ortal.
raja.cedt
Re: Vdsat vs VOD
Reply #1 - Aug 12th, 2013, 1:02am
hello,
Linear region........vgs-vth(vod)>vds....hence Linear region.
Kevin Aylward
Re: Vdsat vs VOD
Reply #2 - Aug 12th, 2013, 9:43am
Comment: Vgst (vgs-vt or vod) is *approximately* equal to vdsat, so they get interchanged in paper and pencil analysis. Analog is all about approximations. 110mv IS ~ 140mv. Regions are not sharp. If you want full, high output impedance (low gds), you should run a few hundred mv over the alleged vgst, possibly 1/2V!
Kevin Aylward
harpoon
Hampshire
Re: Vdsat vs VOD
Reply #3 - Aug 13th, 2013, 2:32am
I am not familiar with 65nm models ... but in BSIM4, if vgs-vt(vod)>0 and  vds > vdsat, you are in saturation.
however, there are 3 different saturation regions depending on vds ... namely channel length modulation (CLM), DIBL and Substrate Current Induced Body Effect (SCBE), as vds is increased beyond vdsat.
... at least that is what spectre is reporting.
I would check the hspice and process model manuals if you are still curious.
This is all academic of course ...
... Kevin's comments makes more practical sense !
