mixed_signal
In a simple transient simulation setup where 50 ohm RF port is loaded with 50 ohm resistor load and voltage in RF port is set to 10uV (say) then we get 10uv at output which is perfect. But when load changes to say 200 ohm then swing is 16uV. How is that possible?
