Jul 16th, 2024, 7:31pm
Simulating a mixer in spectre RF (Read 2254 times)
mixed_signal
Aug 20th, 2013, 12:07pm
In cadence tutorials they recommend to match  mixer output using an ideal Balun to 50 ohm. For this you need to know the magnitude of output impedance (Zout of mixer). How do you find the mixer output impedance?
Or just do a transient simulation for different values of  termination resistor of 1:1 balun?
aaron_do
Re: Simulating a mixer in spectre RF
Reply #1 - Aug 20th, 2013, 5:50pm
are you designing a standalone mixer or is it part of an SoC? If it is not standalone, I don't think you need to match the output. You should terminate the mixer with its real loading conditions to get an accurate measure of its performance.
In order to find the output impedance, you can run a PSS+PAC analysis. The impedance is found like in the picture below.
Note that if you decide to terminate the mixer using the balun + port, then its even easier to check the output impedance as you can just run PSS + PSP analysis and plot Z or Y parameters.
regards,
Aaron
P.S. here is an earlier discussion on the same topic:
http://www.designers-guide.org/Forum/YaBB.pl?num=1240334878/18
