Sep 2nd, 2024, 11:16am
1T1C DRAM (Read 2495 times)
Oceanamie
1T1C DRAM
Aug 26th, 2013, 10:15am
Hello.  I need some helpful hints.
I have a 1T1C DRAM, 10 fF capacitor with Vt ~ 1 V.
How often does this this individual cell need to be refreshed in order for the charge stored not to drop below 85% of its maximum value?
aaron_do
Re: 1T1C DRAM
Reply #1 - Aug 26th, 2013, 10:17pm
I don't know much about DRAM, but i'm sure you need to know the off-resistance of the transistor. From there just use
85% = e-t/RC
Aaron
Oceanamie
Re: 1T1C DRAM
Reply #2 - Aug 27th, 2013, 8:00am
aaron_do wrote on Aug 26th, 2013, 10:17pm:
85% = e-t/RC
Aaron
This is what I'm trying to solve.  I know the charge at 300 K and 400 K easily enough from the graph, but can't find the rest.
aaron_do
Re: 1T1C DRAM
Reply #3 - Aug 27th, 2013, 5:54pm
what do you mean you found the charge from the graph? The charge is just Q = CV. The first question is basically trying to see if you know what is the maximum voltage that can be written. After that, the leakage current is read from the graph. From there, you need to know that the total charge leakage is Q = I*t.
Aaron
