aaron_do
what do you mean you found the charge from the graph? The charge is just Q = CV. The first question is basically trying to see if you know what is the maximum voltage that can be written. After that, the leakage current is read from the graph. From there, you need to know that the total charge leakage is Q = I*t.
Aaron
