Aug 15th, 2024, 4:56pm
Class B power amplifier. (Read 1339 times)
baab
EA
Aug 28th, 2013, 10:31pm
Hi, please help me understand about class B power amplifier. Thank you.
baab
EA
Re: Class B power amplifier.
Reply #1 - Aug 28th, 2013, 10:32pm
The second image:
raja.cedt
Reply #2 - Aug 29th, 2013, 4:02am
Average voltage across inductor is zero over the cycle, so please integrate the voltage and make it zero surely you will find the solution.
summi
Reply #3 - Aug 30th, 2013, 7:38am
Dear Raja.cedt,
I did intergration, no ans.
Br,
Summi.
« Last Edit: Aug 30th, 2013, 10:07am by summi »
raja.cedt
Reply #4 - Sep 1st, 2013, 9:41am
Rough derivation....
Raj.
baab
EA
Reply #5 - Sep 3rd, 2013, 8:21pm
Thank you, Raja and sorry for the late reply.
I still has two questions I am confused.
1. In your answer, the voltage above VDD is Vp/π. I can't figure out why Vp = Ip*Rp* 2√2
Can you tell me why?
2. Can you tell me why the voltage at points X, Y (Drains of M1 and M2) has the shape like that? I think it should be a sinosoid but not. Here is my thought:
Vx = VDD -  VL
Where VL is the voltage across half of primary winding.
VL = Ldi/dt
With ID1 has the shape said above, then Vx has to be a sinosoid.
Can you tell me where I am wrong?
aaron_do
Reply #6 - Sep 4th, 2013, 5:47pm
The author has simplified the load. The transformer is assumed to be ideal, and so the load seen by the transistors is purely real. So the output waveform is just the current waveform multiplied by a constant.
Aaron
