Sep 2nd, 2024, 5:14am
question on the loop gain of this circut (Read 2047 times)
RaDex
Sep 06th, 2013, 12:41am
Hi , I recently joined this forum.
Iam working on the design of a fully differential folded cascode ota to be used in a switched capacitor integrator block of a sigma-delta modulator. Iam using Cadence IC614 for circuit design and simulation. I did some simulation to check the open loop gain, GBW shown below.
Next I made a testbench to measure the loop gain and phase margin by Stb analysis.
Question is on the loop gain as its around -12db which is not correct. Am I doing something wrong here ? Plz suggest
RaDex
Re: question on the loop gain of this circut
Reply #1 - Sep 6th, 2013, 1:26am
Test bench for open loop gain.
RaDex
Reply #2 - Sep 6th, 2013, 1:31am
folded cascode fully differential amplifier with cmfb
RaDex
Reply #3 - Sep 6th, 2013, 1:35am
testbench for loop gain simulation. R1=R2=1Kohms.
RaDex
Reply #4 - Sep 6th, 2013, 1:37am
Frank Wiedmann
Munich, Germany
Reply #5 - Sep 6th, 2013, 4:57am
Something strange seems to be happening in your simulation setup. The annotation of the DC operating points shows 897.3 mV at the input of the diffstbprobe and 0 V at its output. You should of course have the same voltage on both sides. You might want to try if the obsolete cmdmprobe works better for you or build your own diffstbprobe from two ideal baluns connected back-to-back with iprobes between them.
RaDex
Reply #6 - Sep 6th, 2013, 10:09am
i used cmdmprobe but still got th same result
RaDex
Reply #7 - Sep 6th, 2013, 11:11am
i used two back to back baluns with iprobes in between but no change
Can someone help?
nat
Warsaw
Reply #8 - Sep 6th, 2013, 4:34pm
The load of an OTA should be purely capacitive. By closing the loop the way you did (with small resistors), you have loaded your amplifier with resistance, which have caused OTA to fail.
If you want to to that you should add output buffer to an OTA (make an opamp out of it:) )
