Sep 1st, 2024, 3:14pm
Currents are not steady in AMS simulator ... why? (Read 2795 times)
pbennett
Phoenix, AZ
Sep 20th, 2013, 8:07am
I have found that when I plot or measure currents in the AMS simulator that they do not appear to be steady.  Why is this?
I have simulated several different designs ... mostly simple current mirrors and several other circuit blocks and I do not find that the current in AMS/spectre to be solid number like 10 uA ... instead it will numerically oscillate between 9.9 and 10.1ua in a very unpredictable and unsteady way ...
Do I have some accuracy setting wrong ?? Have others seen this behavior before?
pbennett
Phoenix, AZ
Re: Currents are not steady in AMS simulator ... why?
Reply #1 - Sep 20th, 2013, 10:39am
well it seems that just by tightening RELTOLfrom 1e-3 to 1e-5 ... makes a world of difference.
I would still be interested if anyone has any additional guidance regarding this issue.
The simulator of course runs much slower but at least the answers seem to be correct!
Reply #2 - Sep 20th, 2013, 3:24pm
Sounds like trapezoidal-rule ringing. Is it a point-to-point ringing? If so, switch the transient integration method to gear2.
pbennett
Phoenix, AZ
Reply #3 - Sep 20th, 2013, 4:50pm
Yes it seems to be point to point ringing.
I will try your suggestion to move to gear2 method.
TNKS Smiley
