Jul 24th, 2024, 6:27am
DFF frequency divider minimum frequency of operation (Read 2119 times)
aaron_do
Sep 23rd, 2013, 1:17am
I have designed a divide by 2 using a single DFF with Qbar fed back to the input, and found that it has a minimum frequency of operation (around 1 MHz). Below the minimum frequency of operation, the output oscillates at the clock rate instead of half the clock rate. Is this typical? The DFF uses dynamic logic. Also, is there a more robust way to design the DFF so that it doesn't face this problem?
Each latch looks something like this:
--------|Clocked INV>---------------|INV>--------------------->
                 CLK            |-----<Clocked INV|--------|
                                                  CLKB
thanks,
Aaron
boe
Re: DFF frequency divider minimum frequency of operation
Reply #1 - Sep 23rd, 2013, 3:16am
Hi Aaron,
I would expect dynamic logic to have an f_min. A static FF should not have this problem.
- B O E
