aaron_do
I have designed a divide by 2 using a single DFF with Qbar fed back to the input, and found that it has a minimum frequency of operation (around 1 MHz). Below the minimum frequency of operation, the output oscillates at the clock rate instead of half the clock rate. Is this typical? The DFF uses dynamic logic. Also, is there a more robust way to design the DFF so that it doesn't face this problem?
Each latch looks something like this:
--------|Clocked INV>---------------|INV>---------------------> ↑ | | | | | | | | CLK |-----<Clocked INV|--------| ↑ | | CLKB
thanks, Aaron
