Jun 1st, 2023, 2:35pm
Is it possible to attach many images in a post? (Read 5125 times)
baab
EA
Oct 05th, 2013, 8:46pm
I wonder if is it possible to attach more than one image in a post. I usually want to ask questions with attached images but the forum allows only one image per post. Therefore, I have to attach them in two posts, one each time. This is really not good at all.
Is it possible to allow to attach many images in a post, up to threes, for example? Thank you.
harpoon
Hampshire
Re: Is it possible to attach many images in a post?
Reply #1 - Oct 9th, 2013, 1:21am
I guess you can copy and paste into one big image and post ...
baab
EA
Reply #2 - Nov 28th, 2013, 7:05am
Then it is still an image!
I tried to merge many into one but the resolution was so bad.
Reply #3 - Nov 28th, 2013, 7:59am
You can use multiple posts to include all the images.
