Sep 1st, 2024, 7:20am
Why are ro1 and ro2 modeled in parallel here? (Read 3663 times)
baab
EA
Oct 06th, 2013, 2:28am
I am reading about Noise in  Design of Analog CMOS Integrated Circuits Behzad Razavi. Please help me with this question. Thank you.
raja.cedt
Re: Why are ro1 and ro2 modeled in parallel here?
Reply #1 - Oct 6th, 2013, 4:06am
Correct...
To calculate noise 1. Drwa small signal picture 2. Add one transistor noise (could be current or voltage) 3. Find the output voltage/current.
Raj.
baab
EA
Reply #2 - Oct 6th, 2013, 4:50am
Thank you for the confirmation.
aaron_do
Reply #3 - Oct 7th, 2013, 5:51pm
Hi baab,
Quote:
because the transistors are operating in saturation, and so noise can be considered as small-signal
the transistors don't need to be operating in saturation for the noise to be considered small. Noise is usually a small signal. If it wasn't then you would have a tough time detecting your signal inside the noise...
regards,
Aaron
