Hi baab,
Quote:because the transistors are operating in saturation, and so noise can be considered as small-signal
the transistors don't need to be operating in saturation for the noise to be considered small. Noise is usually a small signal. If it wasn't then you would have a tough time detecting your signal inside the noise...
regards,
Aaron
