Harry_108
Hello Experts,
I have formed a very simple code. The code reads the file, if it reads 1 then it writes 3 in another file and if 0 then it writes 7 in another file. Code is as follows:
entity node2 is end node2;
architecture behv of node2 is
signal clk : std_logic := '0'; begin -- behv
clock_gen: process(clk) is --ref: page 143 system designer's guide to VHDL-AMS begin if clk = '0' then clk <= '1', '0' after 50 us; end if; end process clock_gen;
data_log: process is
file input_file : text open read_mode is "node1_out.txt"; variable read_line : line; -- read line string variable input_param : bit; -- read input parameter
file output_file : text open write_mode is "node2_out.txt"; variable write_line : line; -- write output line variable output_vtg : integer; -- write output voltage
begin
if clk'event and clk = '1' then readline(input_file,read_line); read(read_line, input_param);
if input_param = '1' then output_vtg := 3 ; write(write_line,output_vtg); writeline(output_file,write_line); end if;
if input_param = '0' then output_vtg := 7; write(write_line, output_vtg); writeline(output_file, write_line); end if; end if;
wait on clk; end process; end behv;
In the same folder I have a file named node1_out.txt, which has only one element in the top left corner of the file as 1 without single quotation mark.
The Mentors Advance MS simulator gives me following error:
# ** Error: in Top Vhdl-Ams (behv/node2), process data_log at line 24, in the file /mntsse/escience/shende/.SLinux5/Desktop/CNT_Forschung/TP2/co-sim/scams_model/no de2.vhd # ** Error: Textio error : read bit : the line "read_line" is empty # Occurred at time 50 us # ** Error: Simulation failed
Any guesses ???
thanks in Advance, regards, Milind.
