Jul 16th, 2024, 11:29pm
AMPLIFIER DESIGN (Read 1970 times)
smwk
Pakistan
AMPLIFIER DESIGN
Oct 09th, 2013, 11:16am
In designing a two stage power amplifier, can i use BJT or FET in first stage and LDMOS transistor in second stage? What problems can i face? if any..
harpoon
Hampshire
Re: AMPLIFIER DESIGN
Reply #1 - Oct 10th, 2013, 3:39am
The question is really vague ... there are many views, but no one posted as yet. Please post more details if you wish for some sensible answers.
smwk
Pakistan
Reply #2 - Oct 11th, 2013, 9:35am
Actually i want 24.33 dB gain..input is 2.5 W input and output is 678 W output and frequency is 1030 MHz....in second stage if i use LDMOS transistor with 17 dB gain(i m using this transistor because it is high power transistor 600 W with known s-parameters...at such high power mostly the manufacturer does not give s-parameters but gives test circuit)...now for first stage i want transistor with 7 dB gain and on required frequency of operation as far as i have searched mostly LDMOS transistors have high gains ...so dats y i was asking whether BJT or FET transistor is used which have not much higher gains....hope i am making sense...
