Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 17
th
, 2024, 11:27am
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› ADS Antenna Simulation issue
Previous topic
Next topic
ADS Antenna Simulation issue (Read 6155 times)
bradsdr
Oct 10
th
, 2013, 6:49am
Dear Members,
I am new to this forum. I am trying to simulate a
microstrip patch antenna
in ADS momentum. The tutorial I am following is
http://www.carlomozetic.net/userfiles/Tutorial_ADS_momentum.pdf
But results of my simulations are not right I think. I have also attached my results
Any pointers on what could be the issue ? Any tutorial on designing a microstrip patch antenna would be appreciated.
IP Logged
harpoon
Hampshire
Re: ADS Antenna Simulation issue
Reply #1 -
Oct 11
th
, 2013, 1:29am
Looks like a Test bench or setup issue.
Are you sure you have the right model files ? I have not used Momentum before, but I am guessing you need to setup the material properties and antenna X-Y-Z dimensions.
I am guessing you'll need ports correctly inserted for it to work.
If possible, look at tutorials from ADS first to get a hang of the tool.
Good luck and don't forget to report back on where it went wrong and how you fixed it ...
IP Logged
bradsdr
Reply #2 -
Oct 11
th
, 2013, 9:43am
I went through the tutorial again and couldn't find any issue that could give false results. I set material properties and and antenna dimensions similar to what is given in the tutorial. My antenna layout looks like this
I would definitely give feedback on the forum after resolving the issue.
IP Logged
harpoon
Hampshire
Reply #3 -
Oct 11
th
, 2013, 11:42am
One suggestion, can you add another port on your antenna and plot s21 ?
Or better still ... Make a 50 ohm line, put 2 ports at 2 ends, and plot s21. Change to 75ohm and resimulate
Just to confirm momentum is working ...
IP Logged
bradsdr
Reply #4 -
Oct 13
th
, 2013, 12:26am
Thanks for your suggestion. Momentum is working fine. I say this because example that come with momentum is working fine...
I am lost here!
IP Logged
bradsdr
Reply #5 -
Oct 13
th
, 2013, 12:32am
Another question!
How can I find the input impedance of schottky diode using ADS simulation? I want to find out impedance on 2.45 GHz ?
IP Logged
harpoon
Hampshire
Reply #6 -
Oct 14
th
, 2013, 12:33am
I do not have ADS ... but I imagine you can put a DC voltage port on the diode, vary the DC voltage and plot S11 ?
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
