Jul 25th, 2024, 2:16pm
Differential Difference Amplifier (Read 5797 times)
aaron_do
Oct 25th, 2013, 2:09am
I'm looking to design a closed loop differential-in, single-ended out unity gain amplifier. It needs to have very good CMRR. One way to design such a circuit is to use an instrumentation amplifier. However, an instrumentation amplifier drives resistive loads in the first stage, making it a little power hungry. I found such a circuit can also be designed using a differential difference amplifier with feedback.
Does anybody have any experience with this circuit? How does it compare to a normal op-amp in unity-gain feedback in terms of accuracy. Alternatively, does anybody know of other good options?
Any feedback is appreciated.
thanks,
Aaron
wave
Re: Differential Difference Amplifier
Reply #1 - Oct 25th, 2013, 10:47am
Sure, I've designed one with a cascoded current mirror.  Just tack on another Diff pair.  Mine was fully diff'l so I spend a lot of time on CMFB amps.  You should get similar specs to any similar amp of the same technology.  Make sure the CM of input 1 is similar to CM of input 2.
Ref:  Sackinger
Good luck,
Wave   Cheesy
aaron_do
Reply #2 - Oct 27th, 2013, 7:55am
Thanks for the reply.
Yeah I've read that paper. Its interesting. I've just got this feeling that I'm not going to get the same kind of performance as a typical opamp in feedback. I guess I need to do some analysis.
thanks,
Aaron
shaikss_rf
Reply #3 - Nov 26th, 2013, 3:39am
aaron_do wrote on Oct 27th, 2013, 7:55am:
thanks,
Aaron
For one of my designs, I need to design a Instrumentation amplifier using DDA approach. Can you pls throw some light on this?
aaron_do
Reply #4 - Nov 27th, 2013, 12:25am
do you have any specific questions? I referred to a paper in ieeexplore. Just search for Differential Difference Amplifier...
Aaron
shaikss_rf
Reply #5 - Nov 29th, 2013, 2:14am
I, too, referred an IEEE paper. I am designing an Instrumentation amplifier using DDA approach. I tried to optimize the circuit to get desired results but phase margin is very bad. I have attached the circuit and plot.
1.zip
aaron_do
Reply #6 - Nov 29th, 2013, 2:24am
Hi shaikss_rf,
I suggest you attach the images directly to the post, instead of using a zip file.
Aaron
