Sep 1st, 2024, 5:36am
Mismatch coefficient of Capacitors for gpdk 180nm technology (Read 4407 times)
indra0804
India
Oct 29th, 2013, 11:24pm
Hi experts,
I am designing a 8 bit CDAC for the SAR ADC that I want to design for my masters project. Regarding this, I want to know about mismatch coefficient of capacitors (Ac) for gpdk 180 nm tech. because, using the mismatch concept I can decide on the LSB cap value that I need to use.
Anyone having any information regarding this, please help me out....
Indrajit
aaron_do
Re: Mismatch coefficient of Capacitors for gpdk 180nm technology
Reply #1 - Oct 30th, 2013, 2:50am
It might be in the PDK docs, or if you have mismatch models, you could run a monte carlo analysis.
Aaron
indra0804
India
Reply #2 - Oct 30th, 2013, 4:18am
Aaron,
I have checked the GPDK documentations available, but could not find anything mentioned over there. Also, about the monte carlo simulation that you are talking, can you elaborate a little bit more, like what kind of model to use for finding capacitor mismatch...
Anywayz, thanks for the reply.
Indrajit
tm123
Chicago, IL
Reply #3 - Oct 30th, 2013, 10:19am
There should be a mismatch model file included as part of the PDK.  It is usually called something like mismatch.scs or montecarlo.scs.  That model file should include the mismatch data for different devices.  It could also be a section of the typical model file.  Just open the model file you are using to see what is included.
Reply #4 - Oct 31st, 2013, 8:11pm
Hi indra0804,
GPDK is a generic PDK, which has nothing to do with any real foundry process. I don't think it has mismatch data for Monte Carlo simulation.
Go to ask for the PDK from your foundry.
Yawei
harpoon
Hampshire
Reply #5 - Nov 1st, 2013, 3:02am
Hi indrajit,
I happen to have Cadence's GPDK 180 installed (mainly for play).
If you look at the model files, you will find a file called
capacitor.scs
In this model file, you will find some statistics being applied to the cap model (under the "statistics" heading).
Looking at how the model file is written, the statistics part of the model is always included in the netlist ... then it is up to the simulator whether to use it or not.
So in short, if you just need to run ADE XL and set the run mode to Monte Carlo sampling. I think the Cadence docs will be able to help further.
Having said all that ... be warned that this GPDK is NOT a proper foundry PDK ... no clue whether the cap mismatch is realistic or not !
As Yawei mentioned, you are better off designing with a real PDK.
