Aug 16th, 2024, 11:33am
Port in cadence (Read 2532 times)
baab
EA
Port in cadence
Nov 08th, 2013, 7:35am
I am reading this guideline about port in Cadence. Could you explain a bit more about #1 and #3?
port Capabilities
While the port component is generally useful as a stimulus in
high-frequency circuits, it also has the following unique capabilities:
    1. Defines the ports of the circuit to the S-parameter analysis
    2. Has an intrinsic noise source that lets the noise analysis directly compute the noise figure of the circuit
    3. Is the only source for which the amplitude can be specified in terms of power
Re: Port in cadence
Reply #1 - Nov 9th, 2013, 3:23am
Baab,
1)  Spectre's s-parameter analysis recognizes and uses port
    numbers
3) For the port, user can define the input level directly in terms
   of power. For other sources, users need to write equations
   to convert power into voltage so the port is easier to use.
