aaron_do
it might be because your design is non-linear. You have driven your circuit in an unconventional way. I assume you are trying to model some kind of sensor. Your transfer function is proportional to
(100Vin + 100k)/(100Vin + 200k), whose derivative is,
10M/(100Vin + 200k)2
assuming my maths is right. From the equation, the nonlinearity shouldn't really show up, but that's the only thing I noticed that might be causing issues.
Why don't you just model your sensor in a more conventional manner (unless you are trying to see the nonlinearity)? For instance a Norton or Thevenin equivalent circuit? Also, R1 and R4 don't seem to serve any purpose.
Aaron
