Aug 14th, 2024, 1:24pm
resistors has wrong # of segments in extracted view (Read 6050 times)
Nov 12th, 2013, 12:16am
Hi Guys,
A resistor in schematic view has 10 segments in series. In the extracted view, it becomes 10 resistor instances in series. I expect that each one has one segment. Unfortunately, each one has 10 segments now. So the resistance becomes 10 times of that in the schematic view.
The tool is Assura sub-version 4.1_USR3, IC 6.1.5.500.14.
One part of the spectre netlist of that extracted view is shown below.
    u_rdiv\|R3_9__rcx (agnd_h \4\:\#7cu_rdiv\|avC34 \#7cu_rdiv\|avC33) \
	  rpposab_3t_ckt_pcell_0 m=1 segL=7.864e-06 segW=1e-06 mismod=1 \
	  flag_cc=0
	  subckt rpposab_3t_ckt_pcell_0 B MINUS PLUS
parameters segL=8u segW=1.5u mismod=1 flag_cc=1
    R9 (n9 MINUS B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R8 (n8 n9 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R7 (n7 n8 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R6 (n6 n7 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R5 (n5 n6 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R4 (n4 n5 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R3 (n3 n4 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R2 (n2 n3 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R1 (n1 n2 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
    R0 (PLUS n1 B) rpposab_3t_ckt l=segL w=segW mismod=mismod \
	  flag_cc=flag_cc
ends rpposab_3t_ckt_pcell_0
// End of subcircuit definition.
Any comments are appreciated.
Yawei
boe
Re: resistors has wrong # of segments in extracted view
Reply #1 - Nov 12th, 2013, 12:55am
Yawei,
I'd suspect a bug in the PDK.
- B O E
PS: Do you use the tool version recommended by the FAB?
Reply #2 - Nov 12th, 2013, 1:35am
Hi B O E,
That is PDK of SMIC 40 low leakage process. The PDK code is SPDK40LL_1125_1TM(2TM)_OA_CDS. PDK revision is V1.4. Released on 2012-10-11.
You are right. Assura is not listed as a design platform in its release note.  :(
I should go to ask SMIC.
Yawei
boe
Reply #3 - Nov 13th, 2013, 2:31am
Hi Yawei,
we have seen something like this with a different PDK. I just heard our FAB confirmed the bug.
- B O E
Reply #4 - Nov 15th, 2013, 2:13am
Hi B O E,
What's your tool? I have a solution now.
Force segments=1 with the following command in extract.rul.
segments=calculateParameter(length-length+1)
attachParameter( segments, "segments", deviceLayer)
Yawei
boe
Reply #5 - Nov 15th, 2013, 6:09am
Hi Yawei,
we use Assura 4.1, too. So, if I understand correctly, you patched the extract.rul file with these two lines to fix it?
Best regards,
- B O E
Reply #6 - Nov 17th, 2013, 10:04pm
Hi B O E,
Yes, I patched the extract.rul file with those two lines.
My extraction tool is cadence Extraction QRC - 64-bit Parasitic Extractor - Version 12.1.0-s488. But I think that rule is valid for Assura 4.1, too.
Yawei
