Jul 17th, 2024, 10:28pm
constrain number of bits (Read 2447 times)
aaron_do
Nov 13th, 2013, 10:35pm
first off I am new to Veriloga. I am trying to model a digital control loop, but I am storing variables as "real" type. I would like to constrain the resolution of my signals to a certain number of bits to make the system more realistic. Is there any way to do this?
I'm thinking I need the simplest possible ADC function. What I've come up with is :
var = var - var % resolution;
where var is the number I want to constrain, and % is the modulus function. Not sure if this works or if there's a better way though.
thanks,
Aaron
boe
Re: constrain number of bits
Reply #1 - Nov 14th, 2013, 6:26am
Hi Aaron,
your idea is equivalent to rounding towards zero in steps of resolution (sign of % is sign of first operand).
Alternatives are Code:
resolution * ceil(var / resolution)
or Code:
resolution * floor(var / resolution)
(rounding towards +/-infinity).
- B O E
aaron_do
Reply #2 - Nov 14th, 2013, 8:55pm
Thanks!
