Jul 17th, 2024, 1:32am
cadence problem : IP3 with PWL (Read 6162 times)
purplewolf
Nov 17th, 2013, 7:32am
Hello All/Cadence Support,
           I am having the problem figuring out how to run IP3 simulation if the input file is a pwl file. I am easily able to run all other analysis of PSS except the IP3. I have tried PSS+PAC, QPSS which are usual for calculating IP3 but it dont work. For example,with the PSS+PAC analysis the PAC>IPN Curves has the message ''The data for each sideband of the pac analysis contains are frequency sweep.As a result,the above selected function cannot be executed'.
I need urgent help in this regard!
Thanks!
aaron_do
Re: cadence problem : IP3 with PWL
Reply #1 - Nov 17th, 2013, 9:12pm
if you are able to plot everything except IP3, why don't you plot the IM3 and fundamental components and then calculate IP3 yourself?
Aaron
purplewolf
Reply #2 - Nov 18th, 2013, 1:29am
Hi.
 I forgot to mention, i cant plot IM3 components.
tm123
Chicago, IL
Reply #3 - Nov 18th, 2013, 7:51am
What kind of circuit are you trying to simulate?  Although some designers use PSS+PAC to run 2 tone simulations in less time, I think this type of analysis injects the second tone as a small signal so your IP3 result may not be accurate.  What is preventing you from running a 2 tone transient, 2 tone PSS, or 2 tone HB?
purplewolf
Reply #4 - Nov 21st, 2013, 7:50am
There is no option in the port to declare the second signal when i am using input in the form of a text file (pwl file).i oculd no figure out how to simulate??
aaron_do
Reply #5 - Nov 21st, 2013, 5:51pm
since you insist on using your own input file, I assume its some kind of special signal. You could run a transient analysis and to a DFT. Then you can backwards calculate the IP3.
regards,
Aaron
Reply #6 - Nov 22nd, 2013, 9:53am
PSS should work fine with a PWL source. You are using the PWL source to provide the fundamental and using pacmag to provide the test source, right?
rfidea
Europe
Reply #7 - Nov 23rd, 2013, 6:31am
Can you please describe why you are using a pwl file as input. IP3 is measured with two sinus signals as inputs. To me it looks like the easiest way is to use a vsin, isin or a port as input, depending on the input interface.
