harpoon
RG is a critical net, and should not have any current flow across it.
Any coupling to it and you will mess up your CMRR.
So long traces and large loops, are definitely a bad idea. However, you have other constraints to work with ... so another engineering trade off.
Having said that, discrete opamps are not the way forward these days ... better performance (noise) from a single Instr Amp IC, and would make your PCB layout much easier.
in any case ... good luck !
