Sep 17th, 2024, 8:51pm
Pages: 1 2
How to block RF signal? (Read 12064 times)
aaron_do
Re: How to block RF signal?
Reply #15 - Nov 19th, 2013, 10:18pm
you can use a -ve charge pump. It requires a ring oscillator an the charge pump itself. Why do you need a minimum number of components? You're in the wrong design age if you're worried about complexity. Problem is it needs to be on as long as you want to enable/disable, so power consumption is an issue.
I still don't get why you're so keen on using PMOS...
Aaron
shaikss_rf
Reply #16 - Nov 19th, 2013, 10:27pm
aaron_do wrote on Nov 19th, 2013, 10:18pm:
Aaron
I am not worried about circuit complexity. I am worried about power consumption. Since it is  a passive tag and it harvests energy, whatever power I harvest, some of the harvested energy is utilized for Chargepump and other devices.
Even I am not keen about PMOS. As u said, it is PMOS or NMOS, I need voltage source. The only Q is who wil provide the voltage.
During energy harvesting, Rf input signal is in the order of few mV and the control voltage for NMOS SPDT switch is more than the peak of the RF input.
I am thinking of using a start-up circuit to generate required voltage for SPDT switch. Once I get some voltage, then I can enable/disable the switching scheme.
Pls correct me if I am wrong.
shaikss_rf
Reply #17 - Nov 20th, 2013, 1:50am
I have one basic query. For NMOS, bulk is connected to Vss and PMOS is connected to Vdd.
In case of ac signals, RF signal goes negative. In such scenarios, the most negative voltage is the negative peak of RF signal.
How should the bulk connected in such scenarios?
aaron_do
Reply #18 - Nov 20th, 2013, 1:57am
I think you should try reading my earlier replies. I told you the answer several times.
Aaron
shaikss_rf
Reply #19 - Nov 20th, 2013, 2:26am
aaron_do wrote on Nov 20th, 2013, 1:57am:
Aaron
Sorry for repeatedly asking the same.
I understood your point - Pull-up or down to either S/D terminal.
But though I do, pull-up /down, I see bulk current.
Earlier, when I connected bulks to ground, I could see bulk current of 200uA. So, I thought of nullifying it. I tried to do pull up/down, but no significant result.
Not getting how to solve.
shaikss_rf
Reply #20 - Nov 20th, 2013, 2:40am
shaikss_rf wrote on Nov 20th, 2013, 2:26am:
Aaron
Earlier, when I connected bulks to ground, I could see bulk current of 2uA. So, I thought of nullifying it. I tried to do pull up/down, but no significant result.
This is how bulk currents are...
Pages: 1 2
