Aug 15th, 2024, 12:28pm
Substarte parameters for ADS linecalc (Read 2348 times)
mixed_signal
Nov 19th, 2013, 2:26pm
I want to use ADS linecalc for designing a coplanar wave guide on a PCB but the vendor website tells only this :
2-Layers, FR-4, 0.062", 1 oz. cu. plate
Where do i get substrate parameters? If I plug in values for FR4  from wikipedia , will it work. Doesn't they vary from manufacturer to manufacturer?
aaron_do
Re: Substarte parameters for ADS linecalc
Reply #1 - Nov 19th, 2013, 5:13pm
if memory serves, you just need to know the loss tangent and the dielectric constant. You can google it or yeah use the values from wikipedia, but as I remember, the loss tangent of FR4 can vary widely. Also, it has been a while since I did this, but I believe ADS momentum will give you a more accurate result.
regards,
Aaron
