Sep 2nd, 2024, 1:18pm
Comparator _ Opamp based (Read 3407 times)
shaikss_rf
Nov 22nd, 2013, 2:20am
I have used a OpAmp based comparator in one of my designs.  The first file is the circuit. Second and Third are the plots of the comparator inputs and output.. In that, the first sub window is the output of the comparator. Second and third sub- windows are the positive and negative input of the comparator. Though I am varying the inputs to the comparator, I don't see the expected behavior. Though inputs are varying around 1V and there is a significant difference between their inputs, my output is always around 500mV. Can you pls help me out why it is behaving so?
Re: Comparator _ Opamp based
Reply #1 - Nov 22nd, 2013, 9:48am
You should not bundle your figures into a zip file. Few people will bother to unzip file.
Mikay
Reply #2 - Nov 25th, 2013, 3:21pm
Do you have a reasonable matching? If the second-stage transistors size is unreasonable. The output may be stuck even there are input difference.
Mikay
boe
Reply #3 - Nov 26th, 2013, 12:25am
Shaikss_rf,
Check the operating points and biasing conditions.
- B O E
harpoon
Hampshire
Reply #4 - Nov 26th, 2013, 1:46am
can you post device sizes ?
I just tried the circuit topology on 0.18um and it looks ok.
(I won't bias it this way though !)
So most likely due to your current biasing scheme and device sizing as mentioned by Mikay and boe.
