Jul 25th, 2024, 12:48pm
low-vt device property (Read 1783 times)
yvkrishna
Nov 26th, 2013, 11:20pm
lvt device is known for building high speed digital circuits, as the gate cap of the mos(switch) needs to charge to a smaller voltage for switching the state of the device(on/off).
but how can we show the same nature in terms of bandwidth (in terms of gm/cgs) another way to say that its a faster device.
I assume to a first order that when both low-vt and standard-vt  device have nature (similar overdrive for a given current and just that vth is controlled with doping) - may be wrong?
OR some other proces parameter is controlled to make it faster?
yvkrishna
boe
Re: low-vt device property
Reply #1 - Nov 27th, 2013, 3:03am
Hi Yvkrishna,
the speed advantage you describe is a large-signal effect, the low-vt device does not need to be faster (in terms of small signal parameters like bandwidth) for that.
- B O E
yvkrishna
Reply #2 - Dec 2nd, 2013, 10:39pm
Thanks BOE.
