shaikss_rf
I am working on the design of Instrumentation amplifier for ECG system. Initially, I designed a Difference differential amplifier. When I checked the Gain and Phase margin response, the system is highly unstable.
I observed phase margin in negative value and 3dB cut off frequency at ten's of MHz. I tried to add a resistor in series with cap but there is no change in Phase margin.
I did pole-zero analysis:
Poles:
1. -3.22+02 Hz 2. -5.417+07 hz 3. -2.513+07 Hz 4. -9.684e+07 Hz 5. -3.19e+08 Hz 6. -5.27+e08 Hz
Zeros
1. -2.7941e+06 Hz 2. -4.922e+07 Hz 3. -9.679 e+07 Hz 4. -3.14e+08 Hz 5. 6.94232e+07 Hz 6. 2.43 e+09 Hz 7. 9.01661 e+09 Hz
Can you pls tell me how to improve the Phase margin?
