Aug 15th, 2024, 12:29pm
broadband or narrowband match in LNA (Read 2688 times)
baab
EA
Dec 07th, 2013, 11:26am
I need your help again. If I design a LNA with bandwidth = 20MHz, what kind of matching that I need, broadband or narrowband match?
aaron_do
Re: broadband or narrowband match in LNA
Reply #1 - Dec 7th, 2013, 6:26pm
Hi baab,
It depends on the center frequency. For your 1.7 GHz center, 20 MHz is very very narrowband. You need to design your bandwidth so that it accounts for variation in the network's center frequency.
Aaron
baab
EA
Reply #2 - Dec 7th, 2013, 7:23pm
Hello Aaron,
Now I switched to fc = 1.555GHz. Based on your answer, I guess it is also narrowband, right?
May I know what cause the variation?
By the way, I am reading the book you recommended "The Design of CMOS Radio-Frequency Integrated Circuits" by Thomas H. Lee. It is much easier than Razavi book.
aaron_do
Reply #3 - Dec 8th, 2013, 6:41pm
For the LC tank, I suppose process and the accuracy of your modeling would be the biggest errors. Of course part of the LC tank would be made up of your transistor capacitances which are subject to voltage and temperature variation.
Aaron
