boe
Dog1, Re Cmin, I was a bit too fast in answering: you find Cmin under the analysis options (it is used for tran, but not for AC - so it does not apply in your case). Yes, all relevant voltages and currents should be much larger than v/iabstol - and the errors should be in the range of vabstol/iabstol or the relative tolerance reltol. Also, the leakage through Gmin should be much smaller than the difference you are looking for. - B O E
