Jul 24th, 2024, 12:17pm
opamp design (Read 3560 times)
lvbq
Shanghai
opamp design
Dec 10th, 2013, 4:51am
HI all,
In the application of the opamp, see fig1 ,there will a pole in net A because of the input resistor R1 and input capacitance Cp.
Therefore, in my design of a opamp, I want to minimize the  input capacitance of the opamp.what I want  to ask is how to minimize it ?
does the circuit in the fig2 plot work?(for minimize the miller effect  Cgd of M1 &M2 for using the M3 &M4 )
View Profile lvbq   IP Logged
aaron_do
Re: opamp design
Reply #1 - Dec 10th, 2013, 5:51pm
the impedance you are trying to minimize is already small without M3 and M4.
Aaron
danmiso
Re: opamp design
Reply #2 - Dec 11th, 2013, 11:41pm
You can minimize the input capacitance simply by reducing the device size of the differential pair.  This requires reducing the tail current source and/or increase of the over drive voltage of the differential pair.
A problem with your circuit is that the high gain of the opamp is spoiled by the resistance of the feedback.  You probably want to use a two-stage opamp to isolate the cascode of the folded cascode opamp from the resistive load.
AS
US
Re: opamp design
Reply #3 - Dec 12th, 2013, 5:56pm
The drains of M1-M2 differential pair already see a 1/gm impedance, not sure how much you can gain by additional cascoding.
