Jul 16th, 2024, 7:30pm
Confusion about noise factor in LNA (Read 1736 times)
baab
EA
Dec 12th, 2013, 9:00am
I am reading a paper about LNA called "CMOS Low Noise Amplifier Design
Optimization Techniques ".
The author gave the schematic of a cascode LNA topology adopted to apply the CNM technique and noise factor.
I spent two days to prove it but get nothing now. And I wonder why there is no conductance gg in the noise factor of F.
Ing = 4kT*gg*δ*Δf and therefore, I think the final expression of F has to have gg.
PS. I attached the noise factor expression in the second post as the site allowed only one picture per post.
baab
EA
Re: Confusion about noise factor in LNA
Reply #1 - Dec 12th, 2013, 9:01am
Noise factor expression:
tm123
Chicago, IL
Reply #2 - Dec 12th, 2013, 10:27am
The ing2 noise source appears to be included in the parameter 'c' shown as equation (4) on page 2.  I think the ing2 represents the equivalent gate noise which includes the noise generated by the conductance gg, as shown in (3).
baab
EA
Reply #3 - Dec 12th, 2013, 11:15am
Well, thanks. I think you are right.
I have derived many expressions from that paper. However, the one above may be the most difficult. It took me a lot of time to get them but I learnt more.
I will try to get the expression now. BTW, if you know any reference telling how to derive that expression, please let me know.
aaron_do
Reply #4 - Dec 12th, 2013, 5:17pm
T.H. Lee derives expressions for LNA NF in his book.
Aaron
baab
EA
Reply #5 - Dec 13th, 2013, 8:25am
Thanks Aaron.
I have read almost two chapters in the book about noise and LNA but the formula above is not derived.
I have just found an online lecture cover this well.
Now I have a problem need help.
I use TSMC 0.13um then is it short channel or long channel?
How can I find transit frequency, gama, delta, gd0?
tm123
Chicago, IL
Reply #6 - Dec 13th, 2013, 8:51am
I suggest assuming long channel approximation for a first cut calculation.  If you expect your calculated NF to exactly match the simulation you definitely need to account for short channel effects, but the calculation will become too complicated to gain any insight.
When doing calculations like this I never expect my calculation to exactly match simulation, but I expect to be relatively close and more importantly to gain insight into the circuit operation, what the primary contributors to the NF are, and how could I improve the NF of the given circuit architecture.
baab
EA
Reply #7 - Dec 13th, 2013, 4:29pm
Hello tm123,
I will be very happy if my calculations relatively close to the simulation results.  8-)
Thanks for the advice. I am using the cascode structure. Is it really hard to get NF less than or equal to 2 (assuming that we don't need to much gain, for example, gain = 15dB)?
baab
EA
Reply #8 - Dec 14th, 2013, 6:40am
I can't work out the formula above. I tried a lot but don't get it.
I found this lecture: http://www.ece.ucsb.edu/yuegroup/Teaching/ECE219Winter2013/Lecture%20slides%20an...
At the page 9, the professor derived the formula for the same problem. I understand the lecture perfectly. However, as I checked two formulas (the first one is that in original post and the second is the one in the lecture), they are NOT the same. I am sure that the formula in the lecture is correct but can't tell if the one above also right.
I also checked both of them as delta δ =0 and they are different!
The only error I can see in the original is Rs^2 - sLs^2. It should be Rs^2 - (sLs)^2.
If you have derived that formula, please tell me how to do that. Thanks.
Kevin Aylward
Reply #9 - Dec 15th, 2013, 4:48am
Analyzing colliding, rotating black holes tells one that using formulas as above in real designs, is completely futile. So long as you *understand* the global principals of what is going on, running a brute force multiple parameter spice sweep of all relevant components is the way real, optimum commercial designs are done. Sure, academics like to produce formulas and frown on the trained monkey approach. They are wrong.
Kevin Aylward
baab
EA
Reply #10 - Dec 15th, 2013, 5:36am
Hello Kevin,
I agree with you. However, I want to derive the formula myself to get much insight.
I got a document in which they give relatively detailed how to design a LNA and therefore I really want to prove that.
