Aug 15th, 2024, 9:17am
Pages: 1 2 3
NFmin is very low. Is it normal? (Read 20994 times)
aaron_do
Re: NFmin is very low. Is it normal?
Reply #30 - Feb 21st, 2014, 3:45pm
if the output port is not connected, S12 is meaningless. What is S12 when the output port is connected?
baab
EA
Reply #31 - Feb 21st, 2014, 6:33pm
Hi, Aaron.
S11 = -36 dB as output port is connected. I think it is good. However, now S11 is about -6dB.
I used cascode topology. Therefore, I think S12 is not problem now.
Could you check the method to choose Ls and Lg that I did here?
http://www.designers-guide.org/Forum/YaBB.pl?num=1392967942
Is it the right way for input impedance matching?
Pages: 1 2 3
