Hi, Aaron.
S11 = -36 dB as output port is connected. I think it is good. However, now S11 is about -6dB.
I used cascode topology. Therefore, I think S12 is not problem now.
Could you check the method to choose Ls and Lg that I did here?
http://www.designers-guide.org/Forum/YaBB.pl?num=1392967942Is it the right way for input impedance matching?
