Sep 17th, 2024, 6:51pm
Pages: 1 2 3
NFmin is very low. Is it normal? (Read 21141 times)
baab
EA
Dec 16th, 2013, 6:52am
I am simulating cascode LNA in cadence. Below is my schematic with the operating frequency fc=1.555GHz. For the first time, I want to run for Gmax and NFmin. All parameters I set as in the picture. What I am confusing is about NFmin. As you can see in the picture, NFmin is very very small. It is about 106mdB while Gmax also relatively high, Gmax=35.5dB.
I know that NFmin here is what we can get if good noise matching is ensured. But because its value is too low and seem very good! That is abnormal.
Could you please tell me about this? Is there something wrong with my simlation?
Is it good to have very low NFmin like that?
baab
EA
Re: NFmin is very low. Is it normal?
Reply #1 - Dec 16th, 2013, 6:54am
Here is the Gmax and NFmin pictures. Sorry for the inconvinence. I can't attach two pictures in only one post.
baab
EA
Reply #2 - Jan 7th, 2014, 1:59am
I just figured out why the NF is so low. It is because all my components are ideal. The inductors and capacitors are ideal and thefore the noise is only from resistors and two transistors.
In TSMC 0.13um how can I know the internal resistance in each inductor?
aaron_do
Reply #3 - Jan 7th, 2014, 6:22am
The resistance depends on how you model your inductor. The simplest model you could assume would be just a series inductor and a series resistor. In such a case you could simply do a DC simulation to check the resistance. Try reading up on inductor modeling for more complicated models. Also, its a good idea to design your own inductors if you want the best performance.
Aaron
baab
EA
Reply #4 - Jan 17th, 2014, 10:25pm
Hi, can you explain why R = 1k is put there?
Is it used to create a filter together with L = 1H?
aaron_do
Reply #5 - Jan 18th, 2014, 7:56pm
I'm not really sure why the 1kohm resistor is there. I don't think it would have much effect on the frequency response. It might make some sense if you were using practical inductor and capacitor values.
By the way, regarding your NFmin, I haven't seen NFmin that low even for just a single transistor, but I haven't really checked for the more advanced processes. You might want to check the value with theoretical equations just to see if its in the ball park.
cheers,
Aaron
just realised you're using 0.13um technology, so its not that advanced. I didn't know NFmin could be that low...
baab
EA
Reply #6 - Jan 19th, 2014, 1:59am
Thank you, Aaron.
I am following a tutorial about LNA and that circuit is from there together with the resistance R = 1k.
I thought that it will be part of a band-pass filter.
Haha, it is my mistake. In that circuit, only TWO transistors are from TSMC 0.13 and the rest are from Analoglib (standard).
I tried to replace all components by the ones in TSMC 0.13 but NFmin is really VERY high. I want to get NFmin < 2dB but in the simulation, it is always larger than 13dB. Could you tell me your opinion?
How can I get NFmin < 2dB with TSMC 0.13? I am at lost as all components from the library cause noise for the entire circuit.
Also as I know, NFmin doesn't depend on the width of transistors therefore I didn't change them.
aaron_do
Reply #7 - Jan 19th, 2014, 6:46am
Hi baab,
I don't understand what mistake you made in the first place. If you are only trying to find the NFmin of the two transistors, then it is OK to use all other components from analogLib. If you want to use components from TSMC's PDK, then there's no way you can get 1 F capacitors and 1 H inductors. Large values will not substitute well either as parasitic resistance and capacitance will affect their performance. In other words, just use ideal components from analogLib for the simulation of NFmin. If you want to take into account inductor Q, then just assume a reasonable value and add in some resistance.
As for the device width, it might make some difference to the NFmin if the 1kohm resistor comes into play. I would just remove it if I were you as I still can't really figure out what its for. I'm pretty sure it is not part of any filter.
regards,
Aaron
baab
EA
Reply #8 - Jan 19th, 2014, 9:03am
I simulated to get NFmin with components as follows.
Two transistors: rfnmos 2V: TSMC 0.13um
Resistors, inductors, capacitors: analogLib
and the result is that NFmin is very low. It is about 0.125dB.
I read somewhere that to get NF < 2dB is not easy but as in the result NFmin = 0.125dB is incredibly small. I know the difference between NF and NFmin but with noise matching we can turn NF to NFmin, right?
Yes, I tried that but really impossible.
I am wondering why. NFmin is calculated for entire the circuit. And if so, it will depend on Ls, Lg, R..., right?
And when we say that the chip using 0.13um technology, do we mean that all components have to be from TSMC 0.13um?
aaron_do
Reply #9 - Jan 19th, 2014, 5:07pm
Hi baab,
This is the correct method if you want to the absolute lowest possible NF. In the end, you will have to take into account inductor Q.
Its very difficult if you are using on-chip inductors. If you are using off-chip inductors, it is possible to get NF lower than 1 dB even in CMOS. The two big contributors to the LNA NF are the transistors, and the inductors.
Actually there is no point in trying because the results won't make any sense at all. As I mentioned, your inductors play a critical role in the noise performance, and very large inductors typically can't get very good Q. There is some optimal inductor size which will give you the best Q.
Also, if minimum possible NF is really your goal, then you must design your own inductors. It is possible to get significantly better Q by designing your own inductors. Also, if you can make use of bondwire inductance, it also has much better Q than typically found on-chip (its usually limited to around 1-2 nH).
You should also know that any trace of appreciable length will contribute inductance. For example, your PDK's inductor has the position of its terminal defined. But for your design, you might need to run a trace just to reach that terminal. This will contribute inductance, and so it should be taken into account. It really depends on your design though. This is mainly true for high frequency or high power designs.
You must follow the DRC rules (for the most part). That means you can design your own inductors (good idea), capacitors (not always necessary), and even transistors (sometimes people use special layouts for specific applications like high-power designs).
However, in the context of NFmin, you are better off using capacitors and inductors from analogLib, and then adding some parasitic resistance. For example, suppose you need a series inductor, Lg, at the gate. You might assume that it will be about 5 nH at 2 GHz, or 63j ohms. You can then assume a Q of 10. This would put your series resistance at 6.3 ohm. Now simulate your NFmin with a 6.3ohm resistor in series with the gate (don't add any inductance, Lg). Based on your noise plot, your simulation will tell you the actual inductance you need; maybe 70j ohm. Then you can re-calculate the series resistance and repeat the process. Since the resistance depends on the inductance you need, it will be an iterative process.
BTW, L1 in your figure can be substituted with a large resistor (10k for example). L2 may not have much effect on your NF, so it can be considered last.
hope it helps,
Aaron
baab
EA
Reply #10 - Jan 19th, 2014, 7:34pm
Thank you for your insight, it was very helpful.
As you said, I need to take inductor Q into account by using a resistor and an inductor from analogLib.
What is the difference between the inductor got from this (including the ideal resistor and ideal inductor) and the inductor from TSMC 0.13?
I suppose that they have the same series inductance and resistance.
I see.
When you said design, do you mean that I need to change dimensions such as width, number of turns, ... to get optimum value?
I remember that somewhere but I can't figure out why. Could you explain why off-chip inductors give a better NFmin?
I'd like to ask some questions.
1. Because all inductors are not ideal. They have internal resistance. If so, is my initial plot NFmin with the circuit using ideal inductors (from analogLib) and Q = infinity useless?
I feel that because after all we replace all the ideal inductors with other inductors with Q taken into account. And now NFmin will change, not the one before.
2. You said "don't add any inductance, Lg", I am wondering why. Does NFmin depend on Lg, Ls? Assuming that they are ideal (without internal resistance).
Sorry for asking a lot of questions. I can't ask anyone else in my place. Your help and books are what I can find!
I will sum up what I have to do step by step and hope you could help me check if that is OK.
aaron_do
Reply #11 - Jan 19th, 2014, 11:44pm
Hi baab,
I think my explanation was a bit unclear.
This is the main point that you misread. If you are simply looking for NFmin, you don't need to add any inductance at all. You only need to add the equivalent parasitic resistance of the inductor. By definition, the inductance (the imaginary impedance) itself will not have any impact on NFmin. However, you need to make an assumption about what is the parasitic resistance to use based on how much inductance you intend to add. So if you think about it, its an iterative process.
Yes. You can try multiple metal layers, different widths for the inner turns, and you could even try different shapes to fit your design area better.
They are made using much wider metal so they have less series resistance.
As I explained above, an inductor's impedance can be written as R + jX. The value X has no impact on NFmin. So you only need to include R in the simulation of NFmin. You could also do a post-layout simulation of the transistor since the transistor's layout will affect NFmin. After you have found the ideal value for the inductance, you can try and design it with the best possible Q.
Using ideal inductors just lets you know how good or bad your inductors are when you include them later.
I guess I answered this already.
hope it helps,
Aaron
EDIT:
btw, I believe the 1kohm resistor was just to model the noise from the load inductor.
baab
EA
Reply #12 - Jan 20th, 2014, 12:21am
Hi again, Aaron.
Please check if I understand you correctly.
I need to read it many times but here is just what I understand right now.
As I understand, ideal inductor will not cause thermal noise at all. I think this is what you meant in "By definition".
However, my confusion is from the input referred noise sources, Vn and In.
For example, Vn and In, at the input in the application note:
http://www.maximintegrated.com/app-notes/index.mvp/id/3169
(Please see this part:
Figure 3. Again, a noisy, two-port network can be represented as a noise-free, two-port network with external noise sources Vn and In at the input.)
Although, ideal Ls and Lg (let assume that Q = infinity for now) don't introduce any noise to the circuit but the input referred noise sources, Vn and In, will depend on the values of them.
I mean that Vn and In are functions of Ls and Lg.
And NF is a function of Vn, In.
In the end NF will depend on Vn and In. Or NFmin also depend on Vn and In.
In other words, NFmin will depend on Ls and Lg.
I guess I am wrong somewhere. Please let me know. BTW, if you had any proof that NFmin doesn't depend on Ls, Lg, please tell me. I really want to read it.
Now, I think I understood what you meant. Here is what I got so far. I will put it all here. Hope you could check and guide me if I am going astray.
Step 1:
First, I need to run NFmin by sweeping Vgs. From the NFmin plot, I need to choose the value of Vgs that satisfies the specification (for example, NF < 2dB).
Actually, I run it and NFmin is very low in a wide range of Vgs. It looks like that NFmin almost no depends on Vgs. (for example, with NFmin plot in post #2, you can see that NFmin almost constant for a range of Vgs from 0.5 - 0.8V)
Then what criteria should I consider here to pick one Vgs?
I think it is about power consumption. The larger Vgs, the large power consumption.
Step 2:
I need to do power matching.
(gm*Ls)/Cgs = Rs
and operating frequency:
fo = 1/(2*pi*sqrt(Cgs(Ls + Lg))
From step 1, I chose and fixed Vgs. For example, I chose Vgs = 0.7V.
Then I run DC analysis and find operating point of transistors.
From that I get necessary values such as:
gm: transconductance of common source transistor
Cgs: from DC operating point, I got Cgg = Cgs + Cgb + ...
And with given Rs = 50 Ohms, I can infer the value for Ls.
Ls =(Rs*Cgs)/gm.
Similarly, from operating frequency formula, I can infer the value of Lg.
Now I have ideal values Ls, Lg.
Step 3. Take inductor Q into account.
With Ls, Lg got above, by some way ( I think based on my operating frequency) I need to find the resistances associated with them.
For example:
With Ls: I got R1 (I chose R1 because the name Rs is dedicated to source resistance)
With Lg: I got Rg.
Now, put R1, Rg into the circuit. No need to add inductance part at all and re-plot NFmin.
From NFmin, I need to consider if it meet my specification. IF not, change R1, Rg ( this also means Ls, Lg will change) and check again.
Do this step until requirements are met.
Quote:
EDIT:
Well, I think you are right. I have just seen another LNA circuit in which
the drain is Rp//Lp//Cp.
aaron_do
Reply #13 - Jan 20th, 2014, 3:55am
Hi baab,
I think for the most part you are getting it. Lg doesn't affect NFmin since Lg is at the input. Ls might affect NFmin. I can't really remember, so you would have to do some analysis. If it is at the input, it won't affect NFmin. If it is after a lot of gain, it will have little effect on NFmin.
As for Vgs, its a tradeoff. It affects linearity, power consumption, and fT. In fact, if noise and gain are your only considerations, a low overdrive voltage can actually be better in some circumstances.
regards,
Aaron
baab
EA
Reply #14 - Jan 20th, 2014, 8:38am
Thank you again!
I want to ask some more questions.
1. After I get the values of Ls and Lg, how can I know the resistance associated with them?
My thought now is that I need to simulate quality factor Q of an inductor in TSMC 0.13um and then calculate parasitic resistance from that Q.
2. Where I need to use Noise circle analysis? At present, I am reading about them but I still not really sure.
I know that if we get noise matching the noise circle will be a point.
And btw, how can we know Zopt?
Here is my opinion.
I will do sp analysis. From that we need to will plot noise circuit with sweeping variable is noise level.
For example, my NFmin is about 1.5dB
then I will sweep NF from 1.5dB to 1.8dB.
With 1.5dB, the noise circle will be a point not a circuit and I will read out the optimum impedance from that point.
Is that correct?
Pages: 1 2 3
