Apr 1st, 2023, 12:19am
simualting for sigma delta noise folding due to charge pump nonlinearity (Read 2689 times)
yvkrishna
Dec 27th, 2013, 10:18am
In the context of fractional plls, the nonlinearity in the PFD+CP transfer characteristic would result in  noise folding which would increase the low freq phase noise.
I want to create a simple setup to capture in spectre simulations using
1.) quantisation noise by using zvcvs ( just by plugging coefficents of NTF of sigma delta modulator(z domain TF))
2.) vcvs to create the nonlinear transfer char using pwl vector/data file (curve obtained from stand alone chargepump simulation  charge  Vs. delta phi (input phase difference))
If i cascade these two sources 1,2 can I really capture the folding effects(intermodulation )?
but what simualtion (ac/tran/pac ) is needed for this kind of situation?
Ofcourse modeling  modulator/chargepump in timedomain or using matlab for the same is fullblown exercise to capture it completely.
yvkrishna
