Jul 24th, 2024, 12:17am
switched capacitor integrator satuartion and low dynamic range (Read 1445 times)
jovial
Jan 07th, 2014, 9:03pm
Hello everyone !!!
I am simulating a switched capacitor based integrator in Cadence. the problem is that the integrator saturates for very low values of input voltages. Also if i give a sinewave input of 100mV amplitude (riding over 0.9V dc; for 180nm technlogy), the output shows a sinewave which never goes below 0.9V.
Can somebody expalin the reason why??? is the output correct???
carlgrace
Berkeley, CA
Re: switched capacitor integrator satuartion and low dynamic range
Reply #1 - Jan 10th, 2014, 6:14pm
You need to give us a LOT more information than that.
What is your schematic?
Are you using ideal amplifiers?
What are you using for switches?
What is your integrator DC gain?
and so on
