Jul 23rd, 2024, 2:16pm
Transformer or Common-mode choke for Ext Ref Input? (Read 1140 times)
Gradient
Jan 20th, 2014, 12:56am
Hi
I am currently working on a ultra-low noise/jitter clock source and am using TI's LMK04828 for frequency upconversion. I would like to add an external ref in- and output (10Mhz standard) for chaining and locking multiple other devices.
I was planning on using a high speed buffer (ADCLK905) to protect and boost the input stage. Now I am wondering whether it is good practice or advisable to also add a transformer (i.e. 1:2 for 50 ohms match) and/or a common mode chocke after the BNC input in front of the buffer?
Same question also applies for the output: would you put a trafo or directly provide the reference output?
Thanks for any advice
