Jul 16th, 2024, 7:20pm
Question about transconductance  relating to cascode LNA (Read 521 times)
baab
EA
Jan 22nd, 2014, 12:53am
I am reading the following paper about LNA.
D.K. Shaeffer, T.H. Lee, “A 1.5V 1.5GHz CMOS Low Noise Amplifier”, IEEE JSSC, Vol. 32, No. 5. May 1997
There is one thing that is confusing. Could anyone help me with the question in the attached picture? Thanks.
aaron_do
Re: Question about transconductance  relating to cascode LNA
Reply #1 - Jan 22nd, 2014, 1:25am
Hi baab,
the maths is very easy. Just find the overall Gm and you will know why...
regards,
Aaron
baab
EA
Reply #2 - Jan 22nd, 2014, 8:17am
Hi, Aaron.
Could you tell a little bit more? The overall Gm  have been given in (9), haven't it?
aaron_do
Reply #3 - Jan 22nd, 2014, 4:59pm
Oh i see...I just quickly read the text in the yellow box... Tongue
You mentioned yourself that the overall Gm is only dependent on the transit frequency. The transit frequency is fixed by the process. But bear in mind that if you were to add additional capacitors here and there (for example across Cgs), you could reduce the effective transit frequency and thereby lower the gain.
Also, don't take the authors words to mean that the design is linear, as gm/Cgs is a nonlinear function of the biasing condition. I think the important point is that your Gm is optimized alongside your fT.
regards,
Aaron
baab
EA
Reply #4 - Jan 22nd, 2014, 7:13pm
Thanks.
With "process" did you mean "technology"? To be honest, I don't know the difference between "process" and "technology".
If so, in my design, I use TSMC 130nm then "transit frequency" will be fixed, right?
According to the definition above, transit frequency = gm/Cgs. And therefore, it will depend on gm and Cgs. In other words, it will depend on the biasing condition.
Why can we say that it only depends on process?
Yes, I see that from the formula transit frequency = gm/Cgs and the product of gain and bandwidth.
Yes, however, I still confused why the author said so. It is clearly that Gm depends on bias conditions.
aaron_do
Reply #5 - Jan 22nd, 2014, 9:21pm
join the club   Tongue
I'm sure a lot of people know the difference, but its not important to me so I just use them interchangeably. People understand.
What I think the author means is that it doesn't depend on device width. However, its not true in practice because if you make the device width really small, then you need a really large gate inductor, and it won't really work because of the finite inductor Q.
Its really not an important piece of information IMO.
regards,
Aaron
BTW, did you figure out what was wrong with your inductance plots?
baab
EA
Reply #6 - Jan 22nd, 2014, 9:51pm
Hi, Aaron.
Quote:
join the club
Smiley
This is the first time I have designed a RF circuit and I will have to learn a lot.
You meant that Gm doesn't depend on device width, right?
Let's me try to explain that.
As device width changes, gm and Cgs change linearly. Therefore, transit frequency = gm/Cgs remains constant with device width.
aaron_do
Reply #7 - Jan 22nd, 2014, 10:38pm
Yes. But again, the degree to which it works in practice is limited...
baab
EA
Reply #8 - Jan 22nd, 2014, 10:58pm
Could you help me with the question in the picture? It is from the same paper. Please let me know if you need more information or the paper. Thanks.
aaron_do
Reply #9 - Jan 23rd, 2014, 12:51am
Hi baab,
I don't quite get your question. The author just calculated the transfer function from the noise source to the output. Is that what you want to know?
regards,
Aaron
baab
EA
Reply #10 - Jan 23rd, 2014, 2:02am
Hi, Aaron.
Yes, I knew that. However, the channel noise, Ind, is already at the output, isn't it?
I want to know why output noise power density arising from Ind is calculated like that. I mean that why we have to divide that for the quantity in yellow box?
aaron_do
Reply #11 - Jan 23rd, 2014, 6:13am
U need to draw the small signal circuit with the channel noise as your input source. The drain noise causes a voltage drop across Ls which results in another current determined by gmvgs...
Aaron
baab
EA
Reply #12 - Jan 23rd, 2014, 7:00am
Thank you, Aaron.
I will try that now.   Smiley
