Sep 28th, 2026, 1:39pm
Reference Voltage in a differential ADC (Read 2537 times)
jockeymonto
abu dhabi
Jan 27th, 2014, 3:55am
Hi folks,
In single ended ADC designs, a reference voltage in an ADC is necessary but what about in differential designs? We have two inputs; a comparator can tell us which one is larger but we need some digital conversion logic to know how large, in digital format. If two inputs are driving DAC capacitive arrays in a differential SAR design can we work out their input in digital format without using any reference voltage? Any thoughts?
RobG
Bozeman, MT
Re: Reference Voltage in a differential ADC
Reply #1 - Jan 27th, 2014, 8:32am
I've had stranger ideas than a referenceless ADC, but an ADC output is simply a ratio of an unknown input to a known reference. Thus you need a known reference.
Reply #2 - Jan 27th, 2014, 5:05pm
RobG wrote on Jan 27th, 2014, 8:32am:
This gets done all the time when the information you want is relative to the sampled input. sample 1 compared to sample 2 and so forth.
Absolute values are sometimes not needed. Digital feedback control systems are one example.
RobG
Bozeman, MT
Reply #3 - Jan 28th, 2014, 6:34am
loose-electron wrote on Jan 27th, 2014, 5:05pm:
Well I believe you, but in that case you are using the other signal as the reference. I guess a more precise statement would have been a ratio between two signals.
jockeymonto
abu dhabi
Reply #4 - Jan 29th, 2014, 2:05am
Thanks RobG. Well i agree that the output of any ADC is (Vin/Vref)2^N - 1 but there are situations inwhich we can use the differential input voltages to make Vref (like BGR circuit in BJT based temperature sensor) instead of allocating dedicated hardware for Vref. Any thoughts on how ratio-metric ADCs differ from conventional ADCs?
RobG
Bozeman, MT
Reply #5 - Jan 29th, 2014, 2:05pm
jockeymonto wrote on Jan 29th, 2014, 2:05am:
OK, you seem to be saying doing it without an explicit voltage reference. If you mean injecting a reference charge derived from BJTs (or a single BJT with different currents at different times), then yes I've seen that done in a pipeline (or was it a delta-sigma?). Might be impractical for a SAR since IIRC a practical design required two caps with a ratio on the order of 8:1, the 8x device switching in a PTAT charge and the 1x device switching in the Vbe. If you aren't talking about that then I don't know Smiley.
By ratio-metric I assume you mean the circuit loose-electron talked about - I've never seen it but would be interested in learning more. Seems like a way to divide two signals.
Reply #6 - Jan 30th, 2014, 10:10am
in the situation I described it is generally done to a Vref, but the value of Vref is not well defined. With that Vsample1, Vsample2, etc can be digitally compared.
The Vref scalar is still there but frequently the absolute value is not that important.
